Can you elaborate on where you are running your rigs? This will help us give you a better recommendation.Anyone have suggestions on good gripy tires for the granite? I'd like them tolook pretty mean too
If you want a set of winter tires, try some paddles. Or maybe the Hatchet MT or the Louise equivalent since you’re outside the USA.Ok thanks, I live out in the country and want to be able to get through snow in the winter time, the main reason I want new ones is for snow and muddy environments
I thought you said “out of the country” ?? I hadn’t finished my first cup of coffee yet ?Ok thx, and I'm inside the USA actually
Not that great. The stock tires are best in grass and gravel. They didn’t do well for me in loose dirt or light snow. I’ve never ran in deep snow or hard pack. I was really busy with work last winter and didn’t get many days off. The year before I was really new to the hobby and scared to run in water or snow.It's all good lol, how u thing stock tires would do on snow etc?
Ahhh I missed that too. 2WD is not my forte. My advice would to be not to spend money on a 2WD rig, but that’s just me. I would spend my money on a 4WD rig. ???Ok, would it be ok if I just leave front tires stock since I have the voltage? And what tires u using On the mega?
I think the stock tires are pretty awesome!!!
I like this , looks really aggressive , Any issues with the fitment , I’m in need on replacing tires since my rear left has a side wall slit about an in inch in diameterCan you elaborate on where you are running your rigs? This will help us give you a better recommendation.
And to give you a little heads up, sometimes a super grippy tire can lead to frustration as they will commonly cause what is called traction roll. This means your Granite will flip over in corners.
If you want a good tire that works well in a lot of environments for the Granite, my vote would be the Badlands MX28 tires.
