Contacted Horizon Hobby they sent me a new ESC and the same issue prevails, they are now sending me a motor, but that is on backorder till March does anyone else have any ideas or solutions?
The things sticking out don't matter anymore I installed a completely new ESC. Yes, the transmitter is on? Could the batteries be dead on it? The light still turns on.Why are there pins sticking out of that connector?
is the receiver and transmitter on?
Yep, it does the sequence then it just flashes red.They same thing is happening with my esc too. Does it turn on and do the whole beeping thing and then just flashes red?
Idk they gave me a new esc so not sure how it could happen on 2.That is so weird. I legit started a thread about the same thing like an hour ago. Do you think there maybe is just a bad batch coming out of the factory?
You could have asked for this motor. They have stock. Same 2050 KV. 4 pole. Same price. Basically the v4 pre-Firma motor. A drop in replacement.Contacted Horizon Hobby they sent me a new ESC and the same issue prevails, they are now sending me a motor, but that is on backorder till March does anyone else have any ideas or solutions?
I took apart the motor yesterday and everything looked ok. All the wiring look fine and the magnets were ok.You could have asked for this motor. They have stock. Same 2050 KV. 4 pole. Same price. Basically the v4 pre-Firma motor. A drop in replacement.
The Firma is due Feb. still on B/O. Its anyones guess when it will actually arrive. You could always "buy a motor". You have no real options here.
I would call HH and ask when they will get the Firma motor and IF you could get the Arrma V4 version instead. Again, the same motor. Just not Firma labeled. An Arrma label.
How long do you want to wait is the question?? Maybe others here will agree? IDK.
ARRMA BLX3660 3200kV Brushless 10th 4-Pole Motor: 4x4 | Horizon Hobby
Be careful, it may be the stock servo that fried the receiver.Fixed it!! Plugged in my Stampede's receiver and it works now.
Ok so mine also blinks red does the whole beep thing and then goes straight to red flashing I’ve tried recalibrating and it does nothing doesn’t even pop a green light to save the setting when you do the full throttle and everything and my steering servo works so wouldn’t that make it the ecs and yes i have reset the ecsBe careful, it may be the stock servo that fried the receiver.
