- Upstate NY
- 4x4-Mega
- Granite
- Outcast 4s
- Typhon 3s
- Voltage
So started on this today. Got it bare chassis basically, no diffs, axles, driveshaft... It could slide like a turtle, guess that's where the term comes from lol
Spent a good amount of time swapping 3S Typhon axle ends on, with the idea I could use Typhon 17mm adapters instead of the stock hex setup. That's a negative, there just about 3-4mm short, so pin hole doesn't come out enough to get said pin through it. So that's a bust, spare parts for the Typhon or upgrade Granite, they'll get used.
Width of the arms at the hub is actually the same front and rear on a 4s, but only matches the rear of 3s, so just swapping on 3s hubs won't fix that. For now I ordered the stock setup, but I'm not giving up on a better setup.
Plan is to steal the HW Max10 SCT from my Granite for now, and ordered a 3670 size 3050kv motor. Either ads-15m or a 20kg Chinesium servo next, saver delete. Still undecided on wheels, really leaning towards 6s Katar from Talion. They're a quarter inch shorter, ¾ inch less offset, and I think the look I'm going for, something just slightly more low and fast.
And yes that's a Mega 48p slipper just placeholding lol
