Simon
Hi,
I was hoping to get some views from people on how often things are likely to fail and how often you can expect to need to service a car.
I have had a Granite BLX for about 3 months now and to take a guess I've probably run 30-40 packs through it.
In that time, I have had:
The maintenance doesn't bother me too much as I think that is half the fun of the hobby but I'd be interested in hearing is this the level of maintenance and failure you would expect with an Arrma car?
Cheers,
Simon
- a servo fail (replaced under warranty),
- the ESC going to LVC early (replaced under warranty, new one working fine)
- the aluminium motor mount warp (bent that back flat with a hammer)
- and just yesterday I blew a driveshaft bearing ring which spewed ball bearings into the power module damaging the pinion and spur.
Cheers,
Simon
