- Middle TN
- Infraction
- Mojave
- Notorious
- Talion
- Typhon TLR
- Vendetta
Sanity check here... first step to removing the hex hubs (Talion is it matters) is to remove the set screw that faces outward, correct? After that the pin should drop loose and you can pull the assembly out.
I put a wrench on the hex hub and using a hex driver managed to break the set screw off inside the hub before it moved at all.
