I removed the motor fins on my rocket 4092 motor so that the heatsink in the picture can have maximum surface area around the motor. I use a bench sander and just grind them away until the surface is smooth. I highly recommend it!
Thermal paste will dry and become a blanket when it’s filled with dirt. Use a thermal pad instead.Too much work and it weakens the can. I just use thermal paste to get things done!
Yes but they were milled that way from the get go. Ridged cans aren't that much thicker to begin with...Weakens the can huh?? Well i wont be putting it into a vice soon hahaha. theres lots of smooth can motors out there.
I put paste on all my heatsync's and while it does harden I don't have a "blanket" of anything. I apply the paste only to the heatsync where it'll be making contact then slide it on. If there is any run over I'm not worried. Fortunately once it hardens it doesn't pick up any dirtThermal paste will dry and become a blanket when it’s filled with dirt. Use a thermal pad instead.
Oh, I see where your confused... I do NOT ever never fill the gaps between the fins on the motor...EVER, the thermal paste makes a good contact with the top of said fins but I do not put enough paste/adhesive on for it to squish into the valleys on the motor's can. Thermal paste loses efficiency the thicker it is so it is pointless to fill gaps with it. Still makes a huge difference to the temps using a pad or paste versus bareThermal paste is to fill in small gaps and imperfections in the cpu and cooler, adding that much actually traps the heat instead of transferring it just as a heads up.
I was just tossing that little tidbit out there as I've seen guys do it like that on Facebook quite a lot.Oh, I see where your confused... I do NOT ever never fill the gaps between the fins on the motor...EVER, the thermal paste makes a good contact with the top of said fins but I do not put enough paste/adhesive on for it to squish into the valleys on the motor's can. Thermal paste loses efficiency the thicker it is so it is pointless to fill gaps with it. Still makes a huge difference to the temps using a pad or paste versus bare
That's nuts,they aren't spreading it out across the surface thin and as even as possible I'd assume. I'm not as careful with solid cans but on the finned cans I try not to fill valleys. That said, if you use an adhesive thermal paste they hardens I dirt doesn't stick and it shouldn't run after the fact...does make it way harder to get off thoughI was just tossing that little tidbit out there as I've seen guys do it like that on Facebook quite a lot.
