The steering and wheel slop is unnaceptable on my V4 Typhon 6S, I really need to do something about it..
Now don't laugh.. and yes, I know it sounds crazy .
To remove slop, which in turn caused control surface flutter from control surface linkages on rc planes.... we used to add a drop of superglue to servo horns where the z bend of the control rod went through. You glued it then just twisted it to break the bond then you had instant slop free moving joints.
Could this possibly work for the pivot balls or rod ends? It would effectively recoat/resurface the non metal surfaces and massively reduce the play. Once the glue set and you broke the bond, the smoother metal surface SHOULD remain free of any set glue. I'm thinking of trying it on my existing steering mechanism to see what happens as I need a new one anyway... but would also like to hear your thoughts on the idea.
It seems to be due to the slop sum of all the individual steering components although the servo saver posts with the bronze bushings seems to be where the majority of it comes from. Does anyone know what size these bearings are?
I'm really not liking the play in the wheels either and just wondering if anything can be done to remove it?
Are there any other aftermarket parts out there which really help..
HR steering assembly upgrade?
HR steering blocks?
Tekno rod ends?
Shims? where to shim exactly?
What parts/upgrades/mods help the most?
Thanks..
HR steering blocks?
Tekno rod ends?
Thanks..
