Next time you need to solder something, try using the lighter.Would a soldering iron really be hotter than holding the blue part of a naked flame on the gear continuously for 2 minutes?
Risky move... Could end up with a car in a river...Tactic I always did. Don’t over complicate things.
remove pinion grub completely.
take truck for a run
eventually the pinion let’s go.
That's a fair point, although I've never tried. Just thought solder had a low melting point. Where exactly should I hold the iron, just anywhere on the pinion gear? ThanksNext time you need to solder something, try using the lighter.
Hold the tip of the iron on the pinion closest to where the loctite most likely is for a couple of minutes.Where would I place the soldering iron?
