Replace servo
Mikea
New Member
Hi,
I have a Granite ESC. Totally newbee at RC. My son's truck servo busted after a few hours of play. Got a replacement servo under warranty. Trying to understand step by step how to swap in new one. One thing that looks tricky is how to remove steering linkage from servo saver.
Any hints or guides to this surgery from RC veterans would be appreciated.
Thanks
oops wrong vid, this was the one I meant to post.
Hi,
Thanks
Here you go....how to get it out and at linkage
Here is one once it is out to remove the servo
Hi Gabe and everyone,
I misidentified the truck. It is actually a Granite Voltage Mega SRS. Any ideas on how to replace servo on this truck? It looks different than the Granite ESC in the video above.
Thanks.
Thanks.
You have a pic of the chassis?
OK, i can't figure out to get the screw on the saver horn to tighten onto the servo. Is it supposed to mate with the gear on the bottom of the servo?
Also is the screen on saver horn left-handed i.e. left to tighten, right to loosen. Neither seems to work.
Any ideas?
Thanks...
