Replaced Servo with savox 0231
Aaron5
Southern Illinois
Talion
I replaced my stock tali on Servo with the savox 0231 and the steering is reversed in it.
  1. Do I need to do anything other than flip the switch on the back of the receiver?
  2. Does the horn need to be off?
  3. Does the end points need to be reset as well?
Thanks
Aaron5
Southern Illinois
Talion
Do I switch it with everything off or turn on the receiver then switch?
Ok the reset do I set the dials back to factory and do the book reset?
Aaron5
Southern Illinois
Talion
That worked, thanks!!! Noticed my front inner hub bearing is toast, is the fast Eddie ones any good?
WoodiE
Kind of good admin
Staff member
Lexington, KY
Kraton 6s
Absolutely! Not only is @FastEddy a member here but I'm known him for years. He's a stand up guy that sells great bearings at an even better price.
Also, like @slick2500 said Boca and Avid are also very reputable names as well.
Aaron5
Southern Illinois
Talion
Thanks woodiE, I’m ordering some tomorrow morning after work.
Does the front shock tower stand straight up and down? I seen mine leans back just a bit. I had it at work and was ran pretty hard. So I’m wondering if I bent the shock tower on one of the crashes. I’m betting I did.
Aaron5
Southern Illinois
Talion
Okay cool. It’s not noticeable unless you really look. Body still fits so I’m not that worried about it. I was just wondering.
JAsquared
BigRock, , Nero, Talion, 4x4-Mega
Thanks
How is the 0231 Savox holding up? I just ordered one myself. I wanted metals gears but this more economically.
I heard buzzing and clicking in my stock Kraton after a hard drive. IM thinking that is what it is.
Aaron5
Southern Illinois
Talion
So far so good. It’s a lot faster than the stock, to me it is. I will have to try and upgrade the Servo mount, it moves a lot more than the stock one does. And I had to remove the bottom of the Servo to get it to slide into the stock mount. I also upgraded the horn with the hot racing horn and steering link. You will need a longer screw to connect the linkage to the Servo saver.(on the talion anyways) the savox is a few mm taller than the stock one.
JAsquared
Will the
will the stock horn and linkage work? Or do you recommend getting upgrade. If so, which one.
Thx
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast 6s, Typhon 3s
As a temporary fix you can use longer screws, I think I used 20mm screws in mine and it is way stiffer than stock.
Aaron5
Southern Illinois
Talion
Will the
Thx
It should work the horn and linkage is the same, will just be a few mm taller. It was recommended to me on here to get an aluminum horn. I just happened to find a good deal on eBay for both the horn and steering link. If I have pics I’ll upload them. I forgot I got a glitch buster with the Servo as well. I moved the linkage to the middle hole on the horn and zip tied the glitch buster to the plate behind the front shock tower.
Is the holes for the mount drilled up that far? I may run to the hobby shop after Christmas Day and get some longer screws.
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
The holes go all the way through as far as I know. Let me double check the length of the screws.
-edit- Just double check and they are indeed m3x20 and trust me when I tell you this use a drill or they take forever to screw in.
Aaron5
Southern Illinois
Talion
Awesome, thanks for the tip!
