Thank you! That’s the answer is was looking for. I’ll check out Stampede compatible bodiesWhen looking at replacement bodies look at the specs especially the wheelbase measurement. Once you find one with the right specs just may have to mark and put new holes in the body for the body posts once you figure out how you want the body centered on the chassis. But some bodies like stadium truck bodies may not be setup for the stock body posts to line up. Some are setup with the body posts close together with places for the rear shock towers to come up so the body sits lower.
A truck body made to fit the Traxxas Stampede would fit pretty easy just have to drill body post holes.
Here's a $19.99 body made for the Stampede on a Voltage (comes in different colors also).
