parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
Need the Vet/Pro help....
Have a Granite 3S BLX. My goal was for all Typhon 6S shocks but was not able to 100% complete that. So here is what I have that arrived:
Concern/Issue:
The springs seem very stiff compared to the Granite OEM setup especially the Outcast assembly...springs look thicker. It takes a lot more effort to compress them over the OEM. For my level of bashing if you want to call it that, I am happy with the OEM spring tension and the 42.5w oil I used in the shocks. I don't know the OEM oil requirement I could not find it so been using 42.5w has been fine...
Question:
What springs and/or oil weight I can replace the above to come "close" to the level of suspension rebound as the OEM but with the replacement assembly above?
I don't know what I need to get close...springs have ratings like xx gf/mm, medium, etc and maybe I need a lighter oil other than the 42.5w. Looking to the vets who have been down this road for advice or links on how to accomplish this? I would like to not change out the piston shaft rod, etc. if possible, not a basher just a weekend fun RC guy so trying to get close. It doesn't have to be at pro level I only want to spend on what I need too .
- Granite Front - Typhon 6S front shocks full assembly
- Granite Rear - Outcast 6S BLX front shocks full assembly
- Axial shock bushings
Concern/Issue:
Question:
