They are awesome.
I wound't completely rule out how stiff the springs are. It's a pretty beastly upgrade, but I'm a noob, so I'm wondering if this adventure of mine will turn into an expensive learning lesson.
Here's the problem with springs, they don't absorb energy, they simply compress and rebound with the same energy put in, like a basketball. The shock fluids job is to absorb kinetic energy by turning it into heat. If you want to absorb more energy, run thicker fluid or smaller piston holes. The springs primary purpose is to return the car to set ride height, and if matched to the shock fluid correctly, will rebound fast enough to keep the tire in contact with the ground, but not so fast that it kicks like a pogo stick.
More info for those interested... http://rctruckstop.com/2011/12/04/monster-truck-shock-tuning/
Great info, I'm going to measure my shocks tonight just to make darn sure I get the right lengths. Is the measurement center to center?
Yes, center to center I believe... If you pull the trigger on these, your going to need some Tekno standoffs for proper fit. I picked up a set of 4 w/nuts on eBay for $10.
