Thanks, they do look nice. My only question now is which size do I get cause I'm measuring 105mm from the center on both mounting holes for the fronts and 115mm in the backGPM make some, they actually have thicker shafts and they're pretty cheap in comparison. If you can't find stock you can order directly from GPM. Haven't tried them myself and not a lot of reviews online, but might be worth a look. Plus as a bonus they do them in about 6 different colours
I got the v3What version mate..if you run V1 or V2..get the V3 ones...
Thanks for the link. I'll just think about it for couple of weeks to decide what to do. I just wish Arrma parts weren't on back orderMy experience with GPM is very limited. I recently bought a few center diff mounts which are poor quality aluminum but are still a bit better than the plastic. As for the shocks. I bought a set for the Slash ages ago that were too short. They ended up overextending too much & 3 out of 4 broke at the piston cap. They still sell the same set on their site. The Typhon shocks they sell are also 5mm too short for both the front & rear. You would have to lower a already low ground clearance buggy in order for them not to explode on you. I would stay clear of that stuff.
I would stick with the stock shocks. The whole set or parts can still be had on eBay.
https://www.ebay.com/itm/Arrma-Typh...um-Shock-Set-Springs-Cap-Shaf-02/123010744371
Do you know for sure which Tekno shocks fit the front and rear of the Typhon? The only information I have found for the Tekno shocks working on Arrmas is for the Kraton, Outcast and Talion.I wouldn't touch those GPM shocks but Teknos can be had for about $80 at Dollarhobbyz.
It's the eb48.3 or eb48.4 shocks. They're pretty much the same shocks for both models.Do you know for sure which Tekno shocks fit the front and rear of the Typhon? The only information I have found for the Tekno shocks working on Arrmas is for the Kraton, Outcast and Talion.
Yeh gpm have 'off the top of my head' 5mm shafts with stiffer springs but will b fitting alum. ball ends instead of plastic from a rock crawler ive been told gives more articulation...but probly will still find a way to break them. I have seen another set on the rear of the nero from the lower A arm to the body post, sumhow...thinkn nothing stronger than tig welding but easier said than done its an art of its own especially alley!!!...any1 kno much about TOP SERCRET RACING motors youtube vids insaneI bented my front shock shaft over a month ago, since then I been waiting for the shock shaft to come in after ordering it. The teknos are little pricey with no shock spring. Are there any other ones to look for?
