Unless something has changed, You don’t need to remove anything on the battery tray. The receiver is just forward of the tray-you can access the screws with a precision driver.
Green, but my ESC is still blinking redWhat color is the reciver? Should be green
So the steering should be 1 and throttle 2Can you take a pic of the radio so I can see how it is plugged in?
Also what is plugged into what port
Turn them so the white wire is on the inside.
don't bother using the gyro. Its garbage.
thank you so much haha that was it! i thought they could only go in one wayTurn them so the white wire is on the inside.
No lolthank you so much haha that was it! i thought they could only go in one way
now do i just screw the receiver case on top of the throttle and steering wires? seems like it would pinch themNo lol
Red is positive
Black is negative
White is signal
good to know i've been working on that for hours lmao
That ?NOOOOOO!!!!!!!! there is a slit in the side of the case with like a rubber or foam insert they slide down...
