basher27
I am in the process of trying to replace the hub on a 3S slipper clutch, and I thought I replaced the same way as I took it apart, but clearly I must be missing something. If you look at the picture I post you can see the hex bolt that tightens the slipper clutch goes almost all the way through, so you will not be able to pop back in to the rear input gear I do see there is a nylon nut on the old hub that is not here. Not sure how to get that out or if there’s any other pieces i’m missing? Thank you for all your help.
