- Granite
- Kraton 6s
- Vorteks
The suspension and direction on my son's Granite is super sloppy and most pivot balls are so worn out that they are not even captured in the ling rod ends anymore.
I will order the composite pivot ball set (AR330515). Is that enough or should I order the rod end set as well (AR330470)?
Is it recommended to change these together? I am guessing they will be equally worn out if they are made from the same material. Are they?
Thanks!
Thanks!
