- Infraction
- Limitless
After a 2 year Covid hiatus, I finally got back to rebuilding my Limitless that I crashed into a curb...it still needs some work, mainly need a few sets of new tires, paint/trim a new body, rear shock setup with rubber bumps, possibly fix front diff pinion because it seems to skip teeth, and modify this wing by trimming a piece off and moving the plastic wing rearward. I'll probably need to invest in a GPS and other odds and ends to really make this professional like shortening the ESC wires and recrimping.
Right now, she is really well balanced down the middle, with a decent weight bias towards the front with the motor and battery moved as far as I could. This is much lighter weight than my previous build with the 7075 JustBashIt chassis and 2 4s batteries. I don't think that matters much, but I like to think it improved my power to weight ratio. I think the way I positioned all the parts is pretty decent and it keeps the area between the wheels empty. Maybe that helps diffuse the air better?
Build List:
Scorched RC full length chassis, battery mounts, and body posts
Perfect Pass carbon fiber kit, most importantly the chassis brace, steering plate, and splitter
PPS single motor mount and center diff holder
Front/rear diff lockers, white lithium greased, shimmed
2x Kraton 134mm shafts for center driveshafts, small pieces of silicone in the drive cups
TP5670CM 2510kV, has the sleeved rotor for a higher max RPM
XLX2 with cap bank, QS8
Powerhobby 8s 6000mAh QS8, strapped in and outdoor velcro'd
Savox 2290SG
Radiolink RC6GS with 3W signal repeater and R8EF receiver
I'll learn fast if this setup works to my liking. I am hoping the servo is fast/torquey enough at speed, single 8s can exceed load requirement, and whether or not it still drives straight. If I really wanted to push it, I would invest in the dual motor setup with same electronics or potentially just do parallel 8s to feed more current. I am not a fan of series.
I haven't driven this past 120mph since it isn't geared tall yet, but I intend to take it to a clean, pedestrian and car vacant road. I will have to get used to speedrunning again and push it to my personal limits first, then when I'm comfortable I may start taking videos of any impressive speed numbers. I bought a DJI air unit which is an FPV camera designed for quadcopters. With a little bit of jury rigging, I'm sure I can mount it to a body and get some cool onboard footage which I think could be unique. A gopro may also fit, but I think I may have trouble stablizing and bracing the camera. I'm thinking I'll need to mount any camera to my chassis brace.
Let me know your thoughts and any suggestions!
Build List:
Savox 2290SG
