Reverse was working?
firstrctruck
nero green first rc. Servo screw came out today. The reverse stopped working to the tax-300. Any ideas how to fix this?
Rebound I think and unsuccessful
Any other ideas.
Thanks for the help
Try recalibrating your remote to your rc. Page 22 in the manual. This happened to my Kraton and recalibrating fixed it. Good luck!
That was was the ticket. Thank you much!!!!!
Cheers
Any idea why that happened?
When redoing the throttle control on page 22 I had to do the opposite brake / throttle to make the truck go the right direction. Is this going to cause an issue?
You should be able to reverse the throttle control on the remote. Then retry calibrating.
You should switch any two motor wires to reverse motor direction then redo the tx/esc calibration.If not you might not have brakes but instant reverse which will destroy your drivetrain.
I was doing it wrong reading the directions
That's horrible
