That's what I'll will be doing just like all my nitros! ?Here's a video (not mine) where someone cut a hole in the chassis of the BRCC under the spur: (skip to 10 min 48 sec):
I'd do both.Is that better than sealing with 3M? Or is that in addition to?
12mm hexes came in and she got her new shoes.
What tires are those?
Was able to get a new spur gear at my local shop and upon taking apart the slipper clutch to install it I found that the spring, bearing washer, and other 2 plastic washers were missing altogether from the car. Called horizon right away and they sending me the maintenance kit for it but it's on order scheduled to arrive at the end of the month. So everyone check your slipper clutches.
Also going to take apart the diffs to see if they even have oil in them at this point since proper QA was clearly not done on my car.
My grantite v3 had no oil in rear diff. And 1/4 oil in front
What do you guys typically put in in the diffs? I used Red and Tacky for my boys Hosim brand RC which was recommended by the Hosim group.
Nice...why go 12mm hex when Proline sells Raid tires that you can change the center on badlands tire to 14mm hex on the tires...
Those are mx28 badlands.
Proline part number 10125-10. Hoping the fact they arent belted isnt going to be a problem.
Thanks. Im new to the hobby, im still waiting for my BRCC be shipped. Do I need any adapters?
Welcome to the hobby...Thanks. Im new to the hobby, im still waiting for my BRCC be shipped. Do I need any adapters?
