RIG PICS
  1. Talion
Just wanted to check out what people are doing under the hood. I can read and read posts and threads but I'm also a visual learner. The reason im asking is cuz I'm seriously debating blowing the whole truck apart. Cleaning, repairing, upgrading, etc and while disassembled taking advantage of the situation by putting effort into the rebuild rather then being lazy.
Upon replacing all the bearings in my Infraction this weekend,
Did you notice your if your center diff bearing were shot when you replaced them? Mine were trash after the first 4 battery packs.
I've replaced the diff oil in the center diff twice since purchase, back in end of July. This being the third time, I've never had issues with the center diff bearings ever. Nor, any of the other differential bearings. I actually still have them as back ups for a worse case scenario sort of situation.
Full transparency, I made a few 110mph passes before I noticed they were trash. Once I switched to the spool the bearings on the diff were about to fall apart.
Stretched Typhon
Castle MM2 and TP Power 4060
Savox servo
Home made cap pack with audio grade caps
HR Aluminum chassis braces.
Spool and GRP Tires
Stretched Limitless full carbon fiber build:
Castle XL-X esc (8s)
TP Power 4070 (40*107mm can)
DS3225 servo (still testing both red and blue)
Since this picture I have mounted the Limitless shocks and towers back on.
Typhon 6s
Spool and GRPs
Testing the body for the above Limitless project.
