That’s what I have heard but from what I understand it is due to guys overclocking them.
This timeline sucks dk. Sucks. I reckon March is when I'll really be able to get in in with the esc considering work hammering me til then anyway.
Doesn’t the Mamba X also have the bus bars? I heard that was an improvement over the mamba max pro. What even are bus bars lol. I’m no tech guy.The MMX does not have any type of amp limiter. I've pushed 300+ amps through it multiple times with no issues. What it does have is a stricter thermal cutoff, which keeps the ESC alive, helps with warranty etc. The MM1/MM2 will just keep going and does not care if it melts. The MM1/MM2 do indeed have more mosfets than the MMX (36 vs 30). However, the MMX has bus bars whereas the MM1/MM2 do not, which equals the same performance.
To help with this, you can easily install a larger and always on fan, which is what I do to all of mine. I have no problems pushing the MMX with 40x107mm 2000kv motors on 6S with 20T+ pinions, off-road.
It means they have thicker than a PCB traces or a wire. Bars are much thicker and can handle more current.Doesn’t the Mamba X also have the bus bars? I heard that was an improvement over the mamba max pro. What even are bus bars lol. I’m no tech guy.
Oh wowIt means they have thicker than a PCB traces or a wire. Bars are much thicker and can handle more current.
If you need a coupon for the field link let me know.Prolly no coupon but new condition and at this price I'll just buy the CastleLink separately.
Yes. This is a different ESC but shows what they look like. https://oscarliang.com/castle-creations-quadpack-25-esc/Doesn’t the Mamba X also have the bus bars? I heard that was an improvement over the mamba max pro. What even are bus bars lol. I’m no tech guy.
Oscar Liang does a good job.Yes. This is a different ESC but shows what they look like. https://oscarliang.com/castle-creations-quadpack-25-esc/
