I don’t have experience with that exact motor but it should fit fine.I just ordered the rocket 4092 motor and I am going to use it with the stock esc.
Anyone have experience with the rocket 4092 motor? Will I have any problems mounting it in the V4 kraton mount?
I have one in my beast build kraton 6s.. It’s paired with a max6 esc. It’s a monster for sure. There is no fitment issues, fits perfect in the V4 mount ??Pretty sure @Rcproponent onstalled one in his exb, he should be able to tell you how it is.
Mine is a 1650kv.. and my exb has a castle 1717 combo. To be honest, I like both. But the 4092 is perfect for a kraton. You probably won’t have any issues with the stock esc. Just keep an eye on your temps. What kv have you chosen?
I have one in my typhon ? it really is an animal ?I just ordered the rocket 4092 motor and I am going to use it with the stock esc.
@cobalt172 says he's having trouble running it with the stock BLX 185. It's a rebranded Hobbywing 150a esc, so shouldn't it work? I too was considering one of these motors, but if it's not going to run with the stock esc, then that's good information to have. Any thoughts gentlemen?I have one in my typhon ? it really is an animal ?
and am very happy with it.?
but maybe it's a little too much power for a typhon ?
temperature is also good but I do have a double turbo fan and now drive a 17t pinion? and that is enough..
with a 20t he got a bit hot.
But otherwise you will not regret it and also it's nice and cheap ?
It “should” be ok... but better get a max6 just to be sure ??.@cobalt172 says he's having trouble running it with the stock BLX 185. It's a rebranded Hobbywing 150a esc, so shouldn't it work? I too was considering one of these motors, but if it's not going to run with the stock esc, then that's good information to have. Any thoughts gentlemen?
Not a chance, those hobbywing 150A’s (blx 185’s) are the absolute bottom of the barrel ESCs when it comes to 6 cell lipo. Any other 6s esc is ahead of it when it comes to amperage. I will say, most people don’t have weird issues like that, they just overheat. A max8, hobbywing’s other 150a esc, is considerably more capable.@cobalt172 says he's having trouble running it with the stock BLX 185. It's a rebranded Hobbywing 150a esc, so shouldn't it work? I too was considering one of these motors, but if it's not going to run with the stock esc, then that's good information to have. Any thoughts gentlemen?
That sounds like your motor is missing a phase. Brushless motors are a three phase design. Missing one phase has this effect. This could be a bad ESC. Could be a bad motor. Could be a bad wire or connector. You will have to swap parts until you find the culprit.Sputtering, randomly shutting down as if going into thermal protection even though temps were fine. So I just said screw it and ordered a max6
