954kevin
Hey! I have a Kraton 6s EXB v2 as some may already know. I bought a dual 40mm fan assembly from Campfire Carbon and a couple 40mm Rocket Fans from Surpass Hobby.
The dual fan adapter from Campfire Carbon included a fan splitter cable. This cable has 3 pins/wires per side going into a single 3 pin/wire that I assume I plug into the ESC.
However... the Rocket fans only have two pin/wires. So, my question is, can I just plug the two pins from the fans into the 3 pin connector on the splitter? Like, the 2 pin fan connector slides right in to the 3 pin connectors(on only two of the three pins obviously). Here is a couple pictures. I assume this will work fine, but thought I would ask someone with more fan knowledge than myself! I see a lot of the thick boi 40mm server rack fans have three wires. I suppose this splitter from Campfire had those in mind and I assume these rocket fans will work just fine running on only two pin +/-.
Thanks for your help and advice!
