Anyone know if the threads on the rod end side of a 3.5mm and 4.0mm shaft are the same? I’m trying to figure out if the rod ends are interchangeable.
Yes sir, the shock shaft steps down at the threads, hence the reason why Tekno rod ends work for all of the 1/8 Arrma's.Ok, so a 3.5mm shock shaft will thread into the current V3 4mm rod end?
The reason I’m asking all this is because I’m trying to find a shorter spring perch to use on my Hoboa shocks. The shock shafts are 3.5mm and I’d like to find a rod end and perch that were designed to work as a set.
