Rod ends
because the kit works for multiple vehicles, some use the larger one, others use the smaller ones.
So the big or small ?
The small is for steering, the large for rear camber links. The Typhon uses the bent ones in the rear, the Notorious uses one of the short straight big ones on the rear hub, the longer one connects to the tower. Although as an experiment today I have a few rod end sets, so I took the rear camber link on my Notorious and replaced the short rod end on one side with the longer ones to run a "long" rear camber setup with more meat on the threads. If you tighten them all the way and run from inner upper hole to lower outer hub position you get a perfect 2° of camber.?
