dan207265_RC
Does anybody had put RPM a arms on the talion 6s EXB? Will this fit on the front and do I have change the sway bar or used the stock sway bar for the RPM? Any suggestions? Thank you..
No you want these and they bolt right on no other parts needed.Does anybody had put RPM a arms on the talion 6s EXB? Will this fit on the front and do I have change the sway bar or used the stock sway bar for the RPM? Any suggestions? Thank you..
Can I use the stock sway bar on these and what about the rear which one RPM I can use? Well I put this on my kraton 6s EXB already and I had use a bigger saw bar..lolNo you want these and they bolt right on no other parts needed.
Front right https://www.rpmrcproducts.com/shop/...rms-for-the-arrma-6s-v5-exb-line-of-vehicles/
Front left https://www.rpmrcproducts.com/shop/a-arms/front-a-arms/arrma-6s-front-left-arms/
Yes you can use the stock sway bar.Can I use the stock sway bar on these and what about the rear which one RPM I can use? Well I put this on my kraton 6s EXB already and I had use a bigger saw bar..lol
I order this pins I see then on YouTube when this person put them on. They fit good..Yes you can use the stock sway bar.
How did you get the shock pins in?
You need these rear a arms https://www.rpmrcproducts.com/shop/...rms-for-the-arrma-6s-v5-exb-line-of-vehicles/
