MaddMaxx26
- Granite
Does anyone know if RPM part #81392 fits the granite 4x4 blx?
No, not the 4x4 Granite. That part is for the 2WD Granite. The 4x4 Granites use part 81492.Does anyone know if RPM part #81392 fits the granite 4x4 blx?
So what upgrades arms would you run? Aluminum?No, not the 4x4 Granite. That part is for the 2WD Granite. The 4x4 Granites use part 81492.
That said, RPM does not stand behind their products. They are sometimes very soft and bend after install, before even running them. Instead of offering a warranty swap out, I was instructed to boil them and then flatten them and let them cool. I don't see this as a responsible response from a manufacturer. I would NOT buy from RPM.
Hold my beerI cant break an arm on my Granite, so I say stay with stock.
I would avoid aluminum a arms for anything run offroad.So what upgrades arms would you run? Aluminum?
Aluminum a arms are for shelf queens,So what upgrades arms would you run? Aluminum?
