- Talion
Did it break on the same spot?Well..as always, I had to open my fat mouth!! Broke an upper arm on the kexb this weekend!! Operator error, tree jumped out in front of me, but frustrating just the same, popped the lower pivot ball on same side so I suppose I should replace the hub as well?
Hub might be okay. I've popped them in before (the correct way in) and keep on building/driving.
Well a bend like that is completely unacceptable.Hell, even on a 1/10 rig the rpm typhon rears droop bad. So bad that I can run short cvds with no issue. But I don’t jump this truck much, it’s my thrash truck. If they were on a car I jumped they’d be worthless So on my other two cars with typhon arms I run stock without issue.
As for the one 10th scale short arms…I have to replace them every 4-6 months or boil and flatten them out. So I don’t buy rpm arms anymore. Once I’m done with them I’ll stick with stock arms off of Jenny’s. Except for this truck, they work on it
That had never happened to me though
But I keep my RCs with the wheels off and in bags and the arms are off the ground. It's also not hot here... Maybe they bend if you keep it with the wheels loaded or in a warm place?
I mostly keep the wheels off the ground to avoid flat spots in the foams and so the springs don't compress.
They look straight to me
These arms have been there for months. It's only the uppers I've been changing. But have only broke the EXB uppers, never any others. And always on the EXACT same spot
