PshmokN’EM887
So I just got the kraton and bought rpm mud guards and for the life of me I can’t figure out to mount them ! Did I get the wrong ones ?
Thanks man appreciate it now rpm arms here we goThey are meant to work with RPM arms only. If you want something that works with the V5 arms, then check out TBone Racing.
https://tboneracing.net/collections/kraton/products/tbr-rear-mud-guards-arrma-kraton-6s-v5-00041
What size bit you use to drill the holes ?I got rpm guards on EXB arms
I just make a new hole
Rpm arms doesn't fit with those droop screws with a EXB chassis
3mmWhat size bit you use to drill the holes ?
Sælger du demI got rpm guards on EXB arms
Hehe nej desværreSælger du dem
