PshmokN’EM887
So I just put the new rpm from arms and when I go put the shocks in I run into the pin being too long it’s that how it goes I’m sure not but 2 hours wrenching I’m tired
I’m like here we go again with rpm and parts not being bolt on no add ons. So it ok that they stick I was worried I about them falling out .Because Arrma changed the arms for V5's and longer lower shock pins were used. You need the older V4 shorter pins. You can use what you have there. Just that the pins will stick out at the front when the set screw locks in the pin. Shock will still be secure.
RPM never updated their arms for V5. left them as V4's. (using short lower pins)
There was an old thread discussing this.
Can the input gear cause binding?Can't fall out if the set screw is in place. The pin will just be sticking out a few mm. That's all.
Or just buy a set of short V4 lower shock pins at your leisure, if it matters much to you. Your call.
May look awkward to you at first.
