Zgills1
- Dallas, Texas (God's Country)
- BigRock 4x4
- Kraton 6s
- Outcast 4s
@bicketybam I did try their T2T. It mounts to the shock towers. You have to have stock shock towers or the mounting brackets will not work, since they are molded around the stock tower. When I first mounted it I had to push the front tower towards the rear tower to make it sit flush against the towers. The screws had so much tension on them.. when I took them out to access my center diff (Have to remove T2T to get to it) and put them back in the holes, both the front and rear screw holes in the mounting brackets were stripped. Just from screwing them out. I did everything by hand too so I knew I wasn't going to over torque them with the drill.
Anyways, I Jerry rigged the mount so I was able to get the T2T back on (had to shove the towers toward each other again like the first time). Well.. the screws were so tight when I had to take it off again that the hexes on the screw stripped out, and I use MIP drivers - Tbone screws are awful.
Long story short, I run without the T2T now. I am out almost $100 on plastic trash. I now run voltage hobby F&R shock towers (went through like 4 stock rear towers) so I can't use the Tbone T2T even if for some god awful reason I wanted to. . . I figure I will bite the bullet when my stock chassis bends to the point of not being able to run and purchase the M2C chassis.
