• ISDT Q6 Plus 300W Battery Chargers GIVEAWAY
    ENTER NOW!!!
Rpm rear arms
Thread starter #1
robl45
Likes
55
I put the rpm rear arms on to match the front today and I notice that the car cannot get its rear all the way to the ground. Runs out of suspension travel. No issue with the front. Anyone have this?
Paultro84
ArrmaForum Fan
Likes
257
Outcast
That usually has to do with shock travel. I have RPM front and rear with no issues. Push it right to the ground.
Paultro84
ArrmaForum Fan
Likes
257
Outcast
Stock shocks. How to fix?
Post photos so we can see what it looks like with the shocks fully extended and fully compressed.
Thread starter #6
robl45
Likes
55
I can't get photos now. There are smaller tires from racing tonight. It went all the way down with those. Believe it went all the way down with stock arms
Thread starter #9
robl45
Likes
55
tried the different mounting holes at the top. still will not sit all the way down in back.
Mr.Duke
Likes
445
NC
Outcast
What's the difference in tire diameter vs the back flips? Dogbone looks like it's bottomed out and the shocks appear there as well.
Paultro84
ArrmaForum Fan
Likes
257
Outcast
Duke is right. The dog bones are digging in to the drive cups and creating notches. Good eye Duke.
Thread starter #13
robl45
Likes
55
Thats an RPM arm issue I believe, they seem okay, I took it apart to sand that but its not a huge problem right now.
Iamtheoutcast
Likes
358
Massillon Ohio
Kraton, Outcast, Typhon
I have rpm from and rears on my outcast and have no problem getting the chassis in the ground can I ask y decided to mount the shocks in that mounting position on the towers. In the first pic the shocks are mounted in 2 different positions on the towers.
Iamtheoutcast
Likes
358
Massillon Ohio
And that's alot of preload you have there any reason your collars are down so low when the truck is on the ground you want you a arms to b level also what are your grubs set like in the a arms
Thread starter #16
robl45
Likes
55
I was experimenting with the holes in the shock towers to see if that would help, it didn't and I moved the shocks back to the stock holes after I took the picture.
I'm guessing the preload is because of the 6S battery? The front is all the way down and the arms still don't sit level, they are slightly lower than I'd like. I will need to pickup some stiffer springs eventually.
Iamtheoutcast
Likes
358
Massillon Ohio
I only run 6s kn mine and have no issues getting the a arms parral to the ground. u may just need heavier shock oil not springs I run team losi 45wt in mine and I can keep my preload basically at the stock settings. I had no need 2 change the springs the heavier oil will compensate for the un needed preload you have what weight shock lil arr you running.also how far are your drupe screws set 20180515_211025.jpg
Dennis.W
Likes
1
Sweden
Outcast
I replaced stock a-arms today for RPM arms front and rear.
I was looking forward to see how much of improvement it would do and i was very happily surprised! The amount of slack it took away in the a-arms is amazing!
Maybe nothing you mind that much on a car like the Outcast but feels alot better in my mind! The slack in all kind of directions espacially front end is all gone with RPM arms.
No problems with interfering anywhere in travel like above. Maybe RPM have fixed this now.
Similar threads
