Kraton RPM Wong mount🤦‍♂️🤦‍♂️
Installed the RPM wing mount and tried using the stock wing. The holes for the wing seemed like they were stripped out because the hex screw never made up fully. Wing is loose. Should I use a thicker hex or will it screw up wing mount?? Any suggestions will help thanks..??
Do you have the nylock nut in place on the wing mount? That's what the stock wing screw goes into:
