Absolutely like new condition. Was going to make it a proper speed run car but lost interest. Car was ran only 2 runs and that is it! not even a full battery pack.
Removed the splitter cables on esc for more room and to run 1 battery and in doing that the smart function has been removed.
Comes with nice upgrades
EXB front and rear aluminum chassis braces
Arrma aluminum wing post (red)
Arrma EXB chassis brace spacer set
Hot racing rear brace and wing mount
Arrma metal end Ball ends
RPM rear skid plates
ShareGoo Aluminum Center Differential Mount
ShareGoo Metal Center Differential Cover Mount
Team Associated 17mm Offset hubs ( little wider than stock and uses 3mm pins. CVD axles bored to 3mm.
DX3 radio with 6200A DSMR 6-Ch
Spektrum 150 esc and 2050kv motor from my talion exb with extremely low low usage.
Power hobby high speed fan on heat sink and on the esc.
Spektrum S652 servo
GRP S5 wheels
V5 typhon wing (comes with TLR wing also)
The car is setup for speed runs. Droop screws changed with button head screws for better adjustment and will not dig into the chassis.
Price is $475 pick up in socal (orange county). Can drive it before buying.
Spektrum S652 servo
GRP S5 wheels
