I get more than that on 5000mah 50C batteries. You really should go higher than 35C. That's the bare minimum and from what I understand, inadequate.Hi guys I'm just curious to what run times you are getting, I'm running x2 3s batteries 5000 mah 35c and geting about 15 minutes run is this norma thanks.
I run two 3s 5000 mAh 50c batts, and 15 to 20 is my average. If I'm pegging it through grass, gonna be on the shorter end. If I'm on hard pack or gravel, and jumping around, usually a bit longer.Hi guys I'm just curious to what run times you are getting, I'm running x2 3s batteries 5000 mah 35c and geting about 15 minutes run is this norma thanks.
Sounds about right. Best to keep an eye on the temps of your motor, esc and batteries. Hard running in tall grass will heat things up fast. You might not hit thermal cut offs during your runs, but the more you heat things up, the faster they break down. A good temperature gun is a great thing to have on hand, so you can check during your run. Sometimes, letting it sit to cool down can increase the life of the electrical stuff.I have been running it in quite long grass an was peging it like the hole time so would you say that is about average?
Stays at 5000mahThanks mate what batteries are you getting 30 mins out of is that a 6s or 2 3s packs? Also if I'm running 2 3s packs at 5000 mah dose that make it 10000mah or dose it stay at 5000
I would also suggest to rotate your batteries each run, A&B then B&A. I have marked mine with a sharpieHi guys I'm just curious to what run times you are getting, I'm running x2 3s batteries 5000 mah 35c and geting about 15 minutes run is this norma thanks.
