Senton Running the Senton on a track on 2s, what did/would you change?
zeno
I'm considering running my Senton 4x4 BLX on a track vs other Short Course cars.
And they only allow 2s lipo, which I'm perfectly ok with.
What would you change/upgrade on this car going from bashing to racing?
Tires. not much other than that you can do (other then making sure camber and ride height are correct)
Other than tires, the most important tuning you can do is with the front shocks droop, limiting the travel in the front will make the turning more aggressive, so you might want to play with that. Especially if you changed the stock shocks.
Changed TX and RX, that Spektrum abomination just wasn't up to the task.
The track is a hard dirt track.
My shocks are actually working really good for me, will change the oil to... thinner, or harder? I'm bad at this :)
