stiles
- Granite
Before I knew arrma was the best I got a 2wd rustler brushed. I quickly realized I made a mistake and bought a granite blx. I didn’t want the rustler to go to waste so I started modding it. I had leftover parts from modding my granite so I put as much as I could on the rustler. I shorten the rear arms to make it more square and changed to a 17 tooth pinion and 54 tooth spur. It’s insane. It backflips almost as fast as my 4s granite. I couldn’t even hit full throttle without it lifting up. Just the way I like it hahah. I know this is a arrma site just saying that old rustler might be worth dusting off
3s arrma motor and esc
Rpm arms front
Rpm slash rear arms( narrower than stock)
Rpm steering knuckles and caster blocks
Rpm shock tower
rpm transmission cover
rpm turnbuckles front
Arrma turnbuckles
Granite fortress tires
Arrma granite shocks(front for rear)
Slt3 radio
Mod .8 spur and pinion
Fast Eddies bearing set
Rpm arms front
Rpm shock tower
Arrma turnbuckles
Slt3 radio
