S905 kraton 8s servo
Boodaggy
Kraton 6s
I know the servo is 15t spline, but is it savox style? My savox style horn don't fit it.
SrC
Queens, NYC
Limitless, Kraton 6s, Notorious, Outcast 6s
(y) Large Scale servos like most standard servos may require a spline specific horn. Spline counts can vary. Not new. Spektrum and others use differing spline counts. Count the splines. Get the correct horn for the S905.;)
Boodaggy
Kraton 6s
They are both 15 spline that's why I'm asking. The spektrum is listed as a standard mega spline output, the horn is a savox style. The servo for that horn wouldn't fit the stock servo saver, but everyone claims it fits on Facebook. So I am trying to verify what the actual spline type is before I buy another servo. So there is more to it than tooth count. Nothing new.
gotnitro
Fartsville
Limitless, Kraton 8S
There is no Savox style that I've heard of. 15t spline is 15t spline. The stock saver should work with a Savox large scale servo. It's a very tight fit but its supposed to be so you will have to use force while installing it.
  • Like
Reactions: SrC
Boodaggy
Kraton 6s
Ok. I bought a hobbystar servo, it's spec is "15t savox style" and it was a tight fit with the stock servo saver, really tight. So I tried the aluminum horn that came with the servo and it fit the hobbystar servo, but not the stock servo. So when I started looking it up, spektrum lists their servo as a standard mega spline 15t, and the hobbystar was listed as a 15t savox style.
That's when I got lost and couldn't find different servo spline types for 1/5 scale servos.
So all 15t 1/5 servos should fit the stock servo saver?
Boodaggy
Kraton 6s
Yep. Tightly. They are supposed to be. Remember taking the saver off the stock servo? It was really on there. Same thing putting it back on a new servo.
To be honest I didn't think it was that bad coming off. Not as hard as it was trying to put it on the other servo. My next question is then, why does my aluminum servo horn fit the hobbystar servo just fine but will not fit the spektrum servo at all?
gotnitro
Fartsville
Every manufacturers spline can be a few microns off from one another. It would be as simple as aluminum not having the same give/flex as plastic. Just a tad different tolerances could be the meaning of a lose fit but still works to a super hammer on tight fit and it still works. I bet if you muscled the aluminum horn on the lip, screwing it down would suck it in. Don’t try it though, you want that stock saver.
  • Like
Reactions: SrC
Boodaggy
Kraton 6s
I'm going to order a new servo. I don't think I can find replacement gears for this hobbystar. I'll grab that primal servo everyone likes. I'll compare the horn on that one too.
Thanks for all your help.
SrC
Queens, NYC
The Primal is what most go for. In demand too. 1/5 crowd.
Niz55
I am running the hobbystar and works fantastic. You do have to add some washers on the special screw so you can fully tighten the servo savor. Most people don't even do this. Non of the o rings should be visable after installation.
Boodaggy
Kraton 6s
I emailed rcjuice about replacement gears for that hobbystar servo Sunday night. Didn't hear back from them so today I ordered the primal servo. Literally the same time I get my order confirmation through email, rcjuice replied and let me know they just got the gears in stock. So I bought those too! Haha. Crap.
Boodaggy
Kraton 6s
Ok. Got my primal servo. Got some pics while I had it apart. These teeth are clearly different. The dull silver is the primal, copper colored is spektrum, and shiny silver is hobbystar. Primal and spektrum are the same, while the hobbystar is clearly different. Meaning there is more than one style 15t servo.
gotnitro
Fartsville
Where is the screw hole to mount the saver on the hobbystar?
Jimbobjr
SE PA
Kraton 8S, Kraton 6s, Outcast 6s, Talion, Typhon 6s
My Banggood spt 70g servo is not the same as the spectrum either. The servo saver was a little tight and the tapped hole shallower. Works superb though...
Boodaggy
Kraton 6s
It has a screw broke off in it. I polished the end smooth, because I chewed the tip up trying to get the screw out.
Yeah it's a different pattern. My aluminum horn for the hobbystar isn't even close to fitting the stock or primal servo.
gotnitro
Fartsville
So the splines are not cut as far down as the others which would make the saver not go on as tight...
Boodaggy
Kraton 6s
The servo saver would go on, but very tight. It would disfigure the spline material in the servo saver. On the opposite, the servo saver fit just fine on the primal, slid on like all other servo horns do when they match up.
Niz55
The screw broke off because you over tighten it. Like i said, yiu need to add 3-4 small washers and than assemble it.
Create account
Log in
H Kraton Kraton 6s diff pins Arrma 6s BLX 9
Rcproponent For Sale V4 Kraton Classifieds 1
T Kraton Kraton 6s v4 diff/shock maintenance Arrma 6s BLX 6
Dan_OZ Plug&Play motor fan shroud for Kraton 6s 3D Printing 2
Similar threads
