Everything that I have read says that it should be vented so that it doesn't explode if something goes wrong inside. I took the seal on the lid out and drilled two holes in the lid of my ammo box.I just bought this ammobox to keep my lipos when not in use. Its air tight so in case of a fire in the box, would it be better with a vent hole or not, for expanding gases or whatever?
i had an unbalanced 3s that i charged in safebag...started smoking and i pulled it out from charger and rushed to the balcony, just as i open the door swoooosh two 1metre flamethrowers, one on each side out of the bag...all that remains is a connectorI wanted to see what happens with a lipo. Had a old drone 4s lipo with a dead cell. Put a knife in it, some hissing and a lot of smoke was the result. Not the flames i was expecting, but definiately not something you want at home.
