Kraton Saga Custom RC Pinion Gear wobble?
Raydee
NY
Kraton 8S, Talion
I noticed yesterday that my pinion from Saga Custom has some wobble to it. At first I though that somehow I bent the 8mm shaft on my Castle motor but its def the pinion. Has anyone else had this problem?
gotnitro
Fartsville
Limitless, Kraton 8S
I've seen it before but not a SAGA pinion. He gets them from a supplier in china so anything is possible.
Raydee
NY
Kraton 8S, Talion
I may send him an email and see what he says. Its not a bad wobble but its enough to notice.
Batman
Kraton 8S
Here are my Arrma pinion wobbles, only the stock 17 Arrma pinion is dead straight.
24T Arrma pinion
22T Arrma pinion
17T stock Arrma pinion, dead straight.
Raydee
NY
Kraton 8S, Talion
24T Arrma pinion
22T Arrma pinion
Are the 24t and 22t Arrma or aftermarket?
Raydee
NY
Kraton 8S, Talion
Like I said the wobble is not that bad, def not bad enough to send it back.
Niz55
Might be your motor mount is bent. My did that when it was bent. Those big motors are just roo heavy and need rear support.
Raydee
NY
Kraton 8S, Talion
That is possible
How would you say your pinion wobble is in comparison to my 2?
Are you using the stock motor? I will have to take a vid to really compare it
Here is a vid of mine.
Batman
Kraton 8S
That is possible
Stock motor. Yours looks like my 24T one. I've sent my 22T one back to get replaced but no stock until August I think.
jondilly1974
Speed running apprentice, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
My SAGA 34T spool gear (8mm pinion) came with a bit of wobble too. I ended up going down to a 29T anyway so no biggie. For $25 it wasn’t worth the effort to complain.
u189961
Kraton 8S
I installed an Arrma 23t into my K8s last night, it was perfectly straight without any wobbles.
Create account
Log in
Joelk Limitless How to make your own spool using Saga Custom pinion gear Arrma 6s BLX 0
Crewchief227 First set of SAGA gears. Wow! Chassis & Drivetrain 6
Crewchief227 Kraton Ah yeah!!!! Tp SAGA Arrma 6s BLX 3
Joejoe Custom Custom Custom Paint and Body 13
Similar threads
