Savox SA1230SG - external BEC?
rex6638
Oshawa Ontario Canada
I will be putting the SA1230SG in my V4 Kraton. I have a MAX8 esc along with dual motor fans. Will the internal bec of the esc be sufficient for this servo or will I need an external?
It should run fine with no issues. I run (and have run) a very similar setup with dual fans and 1230sg servo. Just remember to run it at 6v as is not rated for higher. That servo is strong! I ran them in my Kraton, Typhon, Limitless, Revo and Ofna GT.
How are you going to run the fans? Through the receiver or off of the balance plug?
Just make sure you set end points correctly. Savox are amp hungry it's over 5amp at stall and each fan to be safe is probably. 5 amp so you are taxing the max 6 a bit. If the esc starts to thermal that would be why. Until then have fun
