I can’t seem to get the Servo through the mount on the Mojave servo mount. What’s the trick to this?
I was afraid of that thank you for your help.Servo looks to big for the mount. If you can’t “angle/wiggle” it in you may have to Dremel or file a notch into the mount.
Do you think this will work for my SW-2290?Yep JBI was the perfect solution for me.
This... and start wire side in first, not smooth side in first. It’s a tight fit but sho fit if it’s a 20mm x 40mm servo size.Take the servo apart. Undo the 4 screws on the bottom and take the top off. Put it in the mount and screw it back together
