ajdragon
- Raider
Hi
Here is a pic of the Stock Arrma steering bell crank next to the Associated SC10 steering bell crank that I am going to put in my Arrma Raider XL. The red arrow shows where I had to grind down the ball stud mount so that the ball stud would be at the right height. I still have to get some more bearings to replace the bushings and get some spacers made to keep it from moving up and down. The bad news is that the nut with the bearing on top of the servo saver has to be perfectly aligned with the lower bearing in order to get a pin to fit through without binding. I couldn't do that so I did what Team Associated did, I made the pin just small enough to get it threw the bearing with out binding. I then mad the ends of the pins small enough to fit into the stock mounting holes. As soon as I get the rest of the parts I will post the finished results. I did do a test fit of the servo save side and I can say this for sure, there will be no more play in my steering anymore. The one thing I wish I had right now is a small metal lathe so that I could make the pins and spacers for other people that wonted to do this mod.
