Kraton Screw tip broke in gearbox
On a related thread. He drilled it out and put in threadserts.
Not going to have room for those type of threaded inserts due to surrounding material required on the 6S gearbox.
Plus, that brass/bronze is probably weaker than even pot metal or china grade aluminium.
For me it is the opposite, I can never cut a slot small enough with the dremel. Maybe my cutting wheels are too thick. Anyways both methods will probably work, just use the one with tools you already have.
I wish I could afford a welding setup 🤷‍♂️
I have the same issue cutting slots.
ALWAYS HAVE A FEW OF THESE AROUND
GEARBOX CASE SET HD 6S
ARRMA #AR310854
Horizon Hobby / Orderable: #ARAC5006
$11.99
I was just going to say or spend the $12 on a new one.
