Vanning
Yeah something reacts quick on those screws and that is something that might be causing it .. At first I thought it was the loctite, cheap hardware and worn tools. Now I have new mounts, new screws, no loctite, good tools and the screws are Installed just snug. After a few runs I go to pull the motor out. Well......
Finally after ripping the skin off my hands, they just free up with severe stress on everything. I know I don't put them in that tight. Now I'll try the anti seize for a while to see what happens.
I really think they get stuck from the tapered portion... so I put the never seize on that and a little on the threads. Idk.
I agree with the anti-seize on the tapers of the screws. Probably a big help later on.Gotcha on the new everything. So if you tighten the screws down and then loosen them right back up, there's no binding? If that's the case then like you said, there must be the stress from the heat and torquing of mounts seizing the face of screw to chassis. Dang 6s power, grŕrr.
Is the plating on the chassis still on the countersunk holes? If not then that would make sense with the dissimilar metals fusing together like 72z15SS stated.
That antiseize is good stuff. It should cure all sticky metal issues.
