StephenSchandelmayer
Rig of the Month Winner
Sup fellas.
Highlight of this build is the basically unbreakable rear driveshafts
Truck comes with
- BLX 185 esc
- hobbystar 4074 2250kv motor
- Full arrma metal diffs and inputs front and rear.
- hot racing diff yolk for the rear only
- Hot racing metal spur gear (also have an extra replacement)
- currently running I believe a 20 tooth pinion (which is slightly worn, might need a new one)
- typhon A arms
- front arrma CVD shafts
- custom rear driveshafts. Uses the rear hubs from a kraton 6s and I welded together a kraton rear shaft to the ball side of a 3s CVD. It works perfectly. There is a limiter in the rear shocks to allow it to work but the truck still sits very nicely off the ground. And being that the front are the stronger CVD you really shouldnt have driveshaft issues.
- I have run this truck on 6s and 4s many times and 6s is just a little silly but 4s is super fast and super fun.
- hot racing extenders on the front for 17 mm wheels (rear has the kraton hex so it's also 17mm)
- typhon 3s wing
- m2c motor mount plate
- animos 25kg servo
- hot racing pivot balls
- granite front bumper
- 40 mm fan on the esc
- (2) 40 mm fans on motor
- J concepts finisher body painted orange with gorrila adhesive to protect it
Truck DOES NOT come with:
- reciever
- radio
- tires
- batteries
Truck comes with
- BLX 185 esc
- typhon A arms
- typhon 3s wing
- animos 25kg servo
- reciever
- radio
- tires
- batteries
