Senton Monster
- Senton 6s
Hello everyone. I just purchased my new Senton 3s 1/10 scale short track truck. This is the best thing sense sliced bread. I've been in RC hobby my whole life. By doing so, I've learned to build and modify many things like planes with a hood scoop, ejection seats, a 16 ft catapult and more so, mods are a fun thing for me. The Stenton is no difference. When I purchased my truck, I planned on shredding it in the mud, or should i say Bashing it. I wanted a truck easy to clean, easy to repair, and have mods out the yaing. Here is my new Senton truck with the mods i made so far. The tires are from Duratrax, I made a body lift so i didn't have to cut the body, i made a mud gard under the body so not to get the electronics filled with mud and debris. also, I had a major issue with rocks getting in the stearing arms and binding up my servo not able to steer my truck at 45 mph (with this set-up clocked with radar. This mod does great. dirt still gets inside but about 90% less. I live in Monroe, North Carolina. Yes the motor will get hot but adding a fan to the motor should fix the issue. I have not replaced my shocks YET but working on it. No it doesn't rubb.
Tires: Duratrax sixpack mt ct part number DTXC3523, 2.8 IN TRUCK MOUNTED 0.5 OFF SET CHROME 2WD (YES 2 wheel drive, yes 12mm hub needs to be changed from 14mm to 12mm.)
Hub adapter: 12mm aluminum wheel Part number DTXC3596. The package says for a Granite 4x4 but will fit PROPERLY on the Senton.
Pinion gear: YOU MUST PUT A SMALLER PINION GEAR TO MOD THE LARGER TIRES. 13t on my Senton I only have a 13, 15, (20T stock), and a 26T position. I put a 13T because that is what the Anderson Hobby Shop had. (P.S. Anderson R/C in Thomasville, North Carolina is one of the 2 best hobby shops I have ever been at in 50 years of my R/C experience.)
The mud gards are made from (For Sale Signs) these are corrigated plastic and garrilla tape. Water proof. Please enjoy and send mod pics.
