Mr.Vylan
If you're in control, you're not going fast enough
- Bay Area, California
- Felony
- Kraton 6s
- Senton 6s
- Senton 3s
I've recently upgraded my Senton 3S BLX 4x4 with a Spektrum RC DX5C w/SR6100AT. I needed to replace the stock servo with the digital servo. Obviously it is not the servo causing the motor reverse lag but wanted to mention what was changed from stock parts.
Everything is working great except the reverse.
When in a full stop, it takes more than 5 seconds to reverse. Sometimes it takes over 20 seconds as if it lost connection.
It is intermittent regarding the lag time.
Since I'm a newbie, I do not want to make assumptions. Open to any suggestions as to what is causing this.
I'm guessing the first step is to rebind and recalibrate. Yes/No?
Thanks in advance.
- Accelerates fine
- Brakes fine
- Steers fine
Thanks in advance.
