Papajohn
- Senton 6s
Hey guys,
New member here ?? I’ve had my 3s senton for about a two months now and have decided to try out different pinion gears such as the 15t and 26t. I tried out the 26t pinion and placed the screws in the designated “26” positions but the screws were so snug to the pinion itself that it wouldn’t allow the pinion to spin so I slapped the stock pinion gear (20t) back on and decided to save the 26t for when my adjustable motor mount comes in.
Now with the 15t pinion, I was able to fit in properly without any issues, but the car became significantly louder- kind of like a high pitched squeal under acceleration. I took the motor apart again, checked the spur gear, checked the pinion to make sure it was secured with the loctite, and everything was fine. It appears to not be slipping at all either? Still accelerates quickly, if not quicker, lol. Could it be that my slipper clutch is too tight? Any input would be greatly appreciated and I’d love to know if you guys had the same experience when installing the 26t pinion. Thank you!
